1 - 3 of 3 Posts
aka The Wizard
alright well since i painted my rims and lowered my car i love the look.....
would it be fine if i pue some wheel spacers on to widen the stance??
if so how big of a spacing could i go???
would i need to roll out my fender too???
We know that anything less than a 40mm offset usually results in rubbing (depends on amount of drop if any, width of wheel, and width of tire as well). Most reports are that this is the minimum recommended offset that will work (subject to above factors also being considered). So lets say you have, for sake of argument, wheels with a 45 mm offset. If you add a 10mm spacer (less than a half inch wide) you end up with the equivalent of a 35mm offset and all the problems that go along with that.
aka The Wizard
ill just stay stock then....
thanks again geezer...
1 - 3 of 3 Posts
