1 - 12 of 12 Posts
What do these numbers indicate on the different wheel & tire packages at WheelMax.com?
(205/40/17)
(215/45/17)
(235/45/17)
(205/40/17)
(215/45/17)
(235/45/17)
Using the first example:
The tire is 205mm wide. The sidewall of the tire is 40% of the width of the tire. The tire is 17 inches across.
Discussion Starter · #6 ·
Would there be any major advantages in getting the more expensive/bigger ones?
Discussion Starter · #10 ·
I don't really need any performance upgrades from the tires, but would there be a big visual difference between the three sizes?
good question I know what the 205 is and I know the 17 but I thought the 40 was 40mm from the ground to the rim.
Microtonal, Do you have the source for the info you posted a link to. I'm asking because I think it contains an error. It says the 205 (in the example provided) is the tread width. I actually believe it stands for the overall width of the tire (sidewall to sidewall). Here's tireracks explanation www.tirerack.com/tires/tiretech/general/size.htm they seem to agree with what i have represented. Could be one of those details that may confuss someone.
1 - 12 of 12 Posts
