1 - 8 of 8 Posts
The manual says to remove the front fender aero shield in order to reach for the bulb, is there an easier way than this?
Take the headlights out and go from above. That is what I did (based on advice here) to change mine out to yellows. Its a tight fit, but it works.
Rubber Side Down
I just had the dealership do it for $20 when I went in for an oil change and rotation.
Sonic Mk3 Crew #03
Turn your wheel left for the right side take the #30 torx out from the bottom and middle fender. Now you have access to your foglamps. Turn the wheel right for the other side...
You da man! Getting someone else to do it is always the best! [:D] (Same way I did mine).
Sonic's Mk3 Crew #17
An alternative is to remove the plastic shield under the front bumper. Screws and a few clips hold it in place, and then you can reach up and undo the bulbs.
AK47 with steel cored eastern euro ammo [gunfire] would definitely change'em. [screwy] And, it wouldn't be much work either. Get video!!! [histerical]
1 - 8 of 8 Posts
