1 - 4 of 4 Posts
After three shops the conclusion is that my 07 Focus needs a new transmission at 112K miles [:(]. I love this car and would like to keep it but can't afford the $2500-$3100 to rebuild the transmission so I am having some friends at the junkyard keep an eye out.
Can anyone tell me what other years have transmissions that would be compatible with the 07?
Thanks!
Hatch Nation #136
First off, what has gone wrong with the transmission that you need to have it replaced? There are one or two common issues with these auto trans that might create sympotms which seem like you need a new tranny, but will actually be easy fixes.
That being said, you can use one from anything between 2000 and 2007.
you need 05-07. if you get a 00-04 you will need to swap the bell housings. the Duratecs have a different bolt pattern.
Discussion Starter · #4 ·
Thanks for the info. I was hoping it was something simple like a solenoid but I've been told that the band is burned out and the drum is physically burned and I have no 2nd or 4th gear.
1 - 4 of 4 Posts
