FYI - aftermarket wheels will not allow the TPMS to work. So you'll have that light going off all the time. Don't see how it would be worth it, especially since those wheels look VERY similar to the OEM 17" painted/machined offerings...I don't mean to hijack this thread but I'm just in the middle of getting one but can't decide which. I've only relied on tirerack.com since they're the only ones that has 16" wheels for 2012 Focus in their configurator that I know.
Anyways, here's what I'm looking to get for my Sterling Grey SE sedan: http://bit.ly/n7ug3T [tirerack.com]
I'm a little worried about the specs since it says 16x7.5 where the stock steel rims is 16x7, I believe. I'm planning on reusing the stock tires, so I'm not sure if this makes a difference.
I was thinking of going bigger (17" maybe) but they said that this might affect your speedo a bit and would need to be readjusted, so I decided I'm gonna go with 16" for now.
you have to buy new sensors, they are the valve stem type...and they work just fineFYI - aftermarket wheels will not allow the TPMS to work. So you'll have that light going off all the time. Don't see how it would be worth it, especially since those wheels look VERY similar to the OEM 17" painted/machined offerings...
Wheel size is largely irrelevant in determining speedo calibration. It's outside tire diameter. Obviously going with too large a wheel will force larger tires, but you can go up and down a few sizes and just get lower profile tires, to keep the same (or similar) outside dimensions.
They won't survive a Canadian winter either, but that's why I kept my still-in-decent shape 16" winter tires off my Vibe. Now I just need a new set of 16" rims for themi got the handling package, so i'm getting the 18". i'm not crazy about the 5 spoke (as a friend puts it "sheriff's badge") rims, but i'll live. will be swapping off the tires though with some decent all-seasons, those "summer tires" aren't going to cut it with WI snow in the winters.
They are the valve stem type. I had the OEM sensors swapped onto my new wheels.Are the tire pressure sensors in the valve stems on the 2012 models? Or are they bands that go around the inner rim? My 2010 e350 and 2008 expedition has/had them in the valve stems. The tire shop was able to reuse them with no problem. Anyone know?
Dittoi got the handling package, so i'm getting the 18". i'm not crazy about the 5 spoke (as a friend puts it "sheriff's badge") rims, but i'll live. will be swapping off the tires though with some decent all-seasons, those "summer tires" aren't going to cut it with WI snow in the winters.
