1 - 6 of 6 Posts
I'm having a horrible time finding anything, especially wheels that look stock.
Can you post what wheels you got, offsets etc. Pictures if you got em.
Discussion Starter · #5 ·
mabye run a 5mm spacer???
Thought about that until I realized it seemed closer to 8mm based on brembo's measurements.
Do you know anyone running 5mm on the 49 offset OEM wheels?
I drive a bit on the mentally insane, and can't afford rub. It seems more and more that I should ditch the BBK. It's really not that necessary after all.
you should get a set of rota boost in 17x7 with a 45mm offset
that should clear the brakes and you wouldnt rub.
1 - 6 of 6 Posts
