looking at some wheels Size: 15" x 7" with +40mm Offset. everything on the car is stock. but will be lowering it to the ground. or as much as possible. remember lower the tire lower the car and happier i will be.
I'm using some 195-50-15 and they're plenty low. I'd be very nervous going any lower.
NICE! Lookin good! [driving]I'm using some 195-50-15 and they're plenty low. I'd be very nervous going any lower.
So does that mean your car's odometer is accruing higher mileage on it that actual?Yeah, I'm about 5+ on the MPH. I use a scangauge and hardly look at the speedo anymore.
No I haven't. It constantly changes if you use instant MPG. It's kind of a distaction when driving. I use the MPH, intake temp, and RPM mostly. The only glitch right now is the unit produces some heat. It's been hot as hell around here lately and when the unit heats up + ambient temp, it will shut it self down so it won't overheat. My AC crapped out, so this just started for me last month.I have a Scangauge...that's an Ultragauge. Costs less and is what I should have bought. How's it holding up?
Have you ever used the Avg mpg and Instant mpg readouts to save gas?
Good thing about the Scangauge is that it sits right above the steering column out of the sun. Bad thing is what I paid. I use the avg mpg/instant mpg/TPS...which tells me how much throttle I'm using/IAT...intake air temp....then occasionally a few others for info when needed.No I haven't. It constantly changes if you use instant MPG. It's kind of a distaction when driving. I use the MPH, intake temp, and RPM mostly. The only glitch right now is the unit produces some heat. It's been hot as hell around here lately and when the unit heats up + ambient temp, it will shut it self down so it won't overheat. My AC crapped out, so this just started for me last month.
You can use Google Earth or a GPS to determine your "real" speed. Even one of those speed indicators the cops put out.Posted via FF Mobile now u say u use a scanguage for your mph. And the stock speedo is +5 mph off. Wouldnt your scanguage be off as well. It is running through you computer and the speedo is running off of a sensor going through ur computer as well. Wouldnt they both be +5mph off?
