1 - 16 of 16 Posts
[???:)] MY WIFE STARTED HER 2000 FOCUS TURNED BOTH DEFRORST ON BEFORE
SHE GOT OUT IT BOGGED DOWN AND SHUT OFF AND WILL NOT START AT FRIST
IT ACTED LIKE IT WANTED TO START ALL LIGHTS WORK THEN I CHANGED THE
ENGINE FUSE NOW IT WONT TURN AT ALL. THE ODOMETER DONT HAVE NUMBERS BUT
DASHES LIKE THIS(------ ------) [?|] [?|] [bash] [pray]
It's been fun.......
I'm not sure what you're saying.. your wife turned both of what on? The front and rear defroster?? What does it do when you turn the key, any lights still work, etc??
Battery???????????????????
FF #1 Most Wanted
Does the car turn over/try to start ?
Do the lights on the dash come on when you try to start it ?
Make sure everything is off when you try to start it.
Radio, air, defrost, lights, etc..
Maybe something shorted out ..?..
It sounds like
Sounds like a dead battery or poor connections. The battery connector problem (covered by the recall but not clearly noted on it) will do this. The bottom line is she is looking for too much current and a poor connection causes it.
When the alternator fails it also does something similar to this.
Good luck.
sounds like you know. please post up if you are ok now.
haha i thought that title was a mess up but i get it now. i still dont fully understand what that dude said in the actual post though
sounds like a ecu problem? i had that when my chip wasn't plugged in all the way. well actually the ports had some of that hunny wax on them. i had to do more scrubin with that lil green pad and some rubbin alcohol
MAXI FUSE
this happened to me to when i was installing lighted pedals. check the maxi fuses, the fuses under your hood, it is one of the orange ones. if its not that then i don't know
1 - 16 of 16 Posts
