1 - 3 of 3 Posts
ok i have 10.2:1 focus central pistons what size gasket should i use to get back close to stock ratio or should i use stock gasket and just get it retuned??
about .030 over stock should get you down to where you need to be. since when you mill your head .040 it raises about a point.
A SVT head gasket will get you down in that range, maybe slightly higher. It's what I'm using to drop from 9.6 around 9.0-9.1
1 - 3 of 3 Posts
