1 - 20 of 46 Posts
The highest I've seen was a Comp Orange with all the bolt ons and a tune putting down 159whp.... Of course you can always make more with some engine work but its usually not really worth it.
I hope this is not a stupid question but, "What are ALL the mods"? So many people have differing opinions on which mods are viable ones and which mods are worthless (even though there is a consensus on all SVTF mods being 5hp or less gains). To be honest, sometimes it is depressing reading this stuff. Having come from a 95 Must GT (on which I did heads, cam, intake, exhaust, gears, suspension, and lighting mods) to my 04 SVTF (only esthetic mods??), I was hoping for doing a little more w/out having to take the FI plunge.....maybe I'm jaded?
If I remember right he had
ORP, 3" exhaust, 65mm TB, lightened flywheel, plugs/wires, tune and I'm sure there was something else. His car was a turbo car that was put back to NA so I'm sure I'm missing something.... keep in mind this was on a completely stock long block.
Now all mods will NOT add power but they do improve the use of the power that is already there... and usually give you a better over all driving experience.
I can see where your coming from being a Mustang guy myself.
Thank you sir...[race]
Shot me 3 deer!!!
I gotta believe the svt can get higher than that!!! compression near 11:1 and p&p job. bet you could get better than 160 whp.
enough to kill my tires today... lol.
its not power. its jsut abuse of fleetfarm purchased fuzion hri's
read much??? I said it was on a stock motor with just bolt ons.
2-Litre, 16-Valve Zetec Engine
Overall development by Oreste Berta S.A.
Main characteristics:
-Format and Mounting: Four-cylinder [straight-4] configuration,
transversally-mounted
-Displacement: 2.000cc
-Bore and stroke: 86 x 86mm
-Compression ratio: 11:1 *
-Valve diametres: 34mm [Induction], 29mm [Exhaust]
-Fuel feed: MOTEC [48mm opening *]
-Electronics: MOTEC
-MOTEC data logger
-Power Output: 300-plus HP at 8.300rpm *
-Lubricants: Elaion 15w 50
[*]: Technical limitations which correspond to TC2000 regulations.
Outstanding features:
- Sump integrated with base of engine block.
- Oval-faced valve gear
- Small-diametre valve springs
- Piston hinges located behind the control ring
- Cylinder-head gasket of great thickness [5mm]
http://www.bertamotorsport.com.ar/ford_eng.php
makes me wonder what I'd have to do to get that engine in my fofo lol.
stock makes 170 crank Hp = ~ 140 wheel hp (whp)
the above 159 is whp
damn u beat me to it ^^
wow the svt loses that much hp in transfer?? I'm gonna do all the bolt ons while I save for a turbo, but thats almost depressing lol.
I have a feeling the loss may be even more because I have seen some really low hp numbers in the dyno thread. Maybe something to do with the heavy flywheel? Or Ford overestimating their numbers, like the 99-01 cobras that had the intake manifold gasket problem.
That reminds that i have to get mine dynoed too.
I got a new lightweight flywheel and clutch kit from luk. And port n polishing my heads in the next few weeks. My buddy does them cheap just cause he likes to do it. hahah.
Whats the SVT putting out with just a good tune and a HFC? Anyone know or have numbers?
1 - 20 of 46 Posts
