1 - 20 of 25 Posts
BAD EGG
Nope, it comes factory filled with 5W30 Motorcraft semi-synth. You will find the most popular oils to be Mobil 1 as well as Royal Purple synthetics in stock weight. If someone tells you to do a search give 'em the finger [:D]
why do we have to kick the dead horse :p
I made the switch to Poyal Purple 5W-30 and have never looked back, that is all that will go into my engine from now on.
Supercharged
inschool said:
No need to kick a dead horse but, It would be niced if you all got the oil weight correct, it is 5w-20, just like every other ford.[:)]
SVT Zetec 2.0 calls for 5w30 - [:D]
I use Mobile 1 Synthetic in my 02 SVT ever since 12k miles.
Shadowrunner,
You can look at YOUR oil cap all day if you want. Then buy an SVT, and read the owners manual.....and be enlightened that it's 5w30.
And although I'm flogging the horse, even though it's friggin dead...."the answer" is Royal Purple (and just to remind everyone...5w30) is the answer.....since Douglas Adams[8] was wrong!
Cheers, Shane
PS. You're always welcome to come stare at my car's oil cap, if that's what you're into!![;)]
I use mobil 1 and didn't even know such a thing as RP even existed until I joined this board. I am curious about the people that say RP is the best the best the best, How can you even tell??? When you start your car in the morning does the front fascia make a big smile indicating the car is happy with RP?
I used RP 20w50 in my Alfa GTV6 and it had 194 miles and still drove strong. Once I pick up my SVTF, that is all I plan on running (just not the same weight). And if you think the oil was thick, it took 8 quarts and it was only a 2.5 liter v6!!
I use Mobil 1 right now and I have since I got the car and I'm at 35,000. But what I want to know is if I change over to RP what difference am I going to notice?? Will it idle better, run stronger, I don't get the difference that it would make.
1 - 20 of 25 Posts
