1 - 13 of 13 Posts
· Registered
so cel comes on, get home pop in my code reader and i get this
code p0125
insuffient coolant temp for closed loop fuel control...
what the hell does that mean???????????
· Registered
Means your motor is running too cool.
P0125 - Insufficient Coolant Temperature For Closed Loop Fuel Control Indicates the ECT or CHT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting engine. Insufficient warm up time
Low engine coolant level
Leaking or stuck open thermostat
Malfunctioning ECT sensor
Malfunctioning CHT sensor
Refer to Thermostat Monitor in Section 1, Description and Operation, for system information.
Do you have a 180deg thermostat?
· Registered
One I would keep you eye on the coolant level , and the temp gauge to see if your thermostat is suck open.
I would get that code when it was cold out and I had the 180deg thermostat, it was really hard to ever get the car to heat up
· Banned
170? why?
im betting that its stuck open. although, most of these things go bad in the winter. for real, every winter, there are about 20 threads that get started just the way you started this one.
1 - 13 of 13 Posts
