1 - 7 of 7 Posts
what do you think of this repair history I got in an Oasis report?
also nothing was found on the carfax report, it was completely clean
Do these repairs sound like anything that should keep me from buying this car?
It's a 2004 SVT 5-door with 32,796 miles
REPAIR HISTORY
03/01/2004 BUILD DATE
04/15/2006
DEALER:
WARRANTY CLAIM NUMBER: ODOMETER: 032656M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
4S4Z 12A650ZA PROCESSOR ASSY 001 12650D 42 DOES NOT OPERATE PROPERLY
5W6Z 9G444BA SENSOR ASY EXH GAS 001 12650DX1
5C5Z 9F472BA SENSOR EXHAUST GAS 001 12650D80
000 12650D81
000 12650D82
000 12650D84
000 9350B
000 12650D6
000 12650D70
000 12650D4
WDS DIAG AND FUEL PRESSURE TEST. P0135, P0141. FOUND PCM DRIVER BAD AND BOTH HEGO SENSORS SHORTED TOGROUND. REPLACE BOTH HEGOS AND PCM, REFLASH-RETES T- OK
04/15/2006
DEALER:
LABOR OP
CONDITION CODE
CONDITION DESC
F4CZ 13466A SMALL BULBS 001 13465A 42 DOES NOT OPERATE PROPERLY
2U5Z 13411DA SOCKET REAR LAMP 001
DIAG AND FOUND SOCKET AND BULB SHORTED-REPLACE SOCKET AND BULB-OK
04/15/2006
DEALER:
LABOR OP
CONDITION CODE
CONDITION DESC
YS4Z 14529BA SWITCH ASY-WINDOW RE 001 14529A 42 DOES NOT OPERATE PROPERLY
000 12651D2
PIN POINT TEST, FOUND SHORTED SWITCH-REPLACE AND RETEST-OK
04/15/2006
DEALER:
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 96R MOTORCRAFT BATTERY 001 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
PIN POINT TEST, CHARGE BATTERY AND TEST-REPLACE BATTERY. ACES CODE H918P DTC CODE 6Q2 D49
Stay the hell away from that !!!!
....but give me the seller's phone number.....so I can uh, follow up or something......
<crossing fingers in hopes that my ruse is believed.....>
Seriously though, it wouldn't keep me from buying it.
cool, thanks for the info[8D]
Seems pretty much good. None of those issues were very serious, but i noted that many were due to shorted-out components. Would it be possible that there was a more serious electrical issue that caused the shorts and could have caused more problems? Judging by the mileage, the car was taken to the dealership just before it was put up for sale. Maybe Johnny-16-yr-old wasted the electrical system installing his million-watt subs and took it to get cleared up before selling the car [?|] See if you can find out about the previous owner or see if all those little issues together might be indicative of a larger problem. Good luck and I hope it works out well for you!
Yeah, normal stuff. Go ahead and buy it if you like.
Welcome to the site!!
Discussion Starter · #7 ·
Thanks for the replies guys, I think I am gonna buy it.
I appreciate the info.
1 - 7 of 7 Posts
