1 - 6 of 6 Posts
I'm looking to fully build my engine. What all do I need to do? It's the zetec motor. Thanks.
Thats What She Said
You are asking such an open ended question that its not going to be answered with to much respect.
I have house I want to remodel the kitchen, what should I do....
Are you boosted? looking for power? rebuild it stock? make it stronger? whats your price point? what work are you going to do your self? do you have a 2nd motor to work on while you are rebuilding? what is your time line?
Apologies. I am boosted. Looking to raise my boost level from 8psi (current) to 15psi. I want to make over 300hp. Close to 400 would be nice but 300 is good enough for me. I'd be doing the work myself. I do not have a second motor. My timeline is within 1 year. My price point is yet to be determined. Thanks.
Great reply by Magus2727.
Based on your wording in the initial post, it seems like you have never built an engine, -or never built an engine of this type, correct?
If this is your first engine build (I assume it is) this is a learning adventure correct? GREAT! -please-please go forward, but you gotta set & understand the money & learning-time needed to do this AND the tooling & likely some outsourced(?) machining needed during this adventure.
The flip-side of this coin is: Purchase a "built" engine (with a warranty) and give that company you core engine to reduce these costs.
The flip-side of this coin is: Consider building a newer engine type. Even if that engine is inside a different model Focus or inside a different car type.
Please note that these old cars with built engines are a money pit and you will not recover these costs during future resell value of the car. Also, the thrill of creating & improving & making a higher-performance car (in any league) is priceless.
Please chose your league and your build; this is usually based on your desired car types & likes + budget.
Is this car the exact year & model AND is this your firm choice for an engine build? It is almost never too late to reconsider the car platform for an engine build; especially if this is your first.
<< Note: The OP has not discussed desires if the car is to be a FAST-Focus milk-getter, or a track car, or a rally car, -or a hybrid of these types...? >>
Engine build budget (and other choices) must be very well researched & decided upon ASAP or... kinda-sorta required in advance of going forward.
DISCLAIMER: I have never built any engine. My comments here are only meant to question & influence the OP in desire and direction.
Good luck snailzx3
Good luck snailzx3
Thank you for your comment. It got me thinking a little more. It will be my first build and I'm hoping to learn more. Resell value is not an issue to me, as I don't plan on selling the car. It means a lot to me. I may be idiotic for trying this but I'll never learn if I don't try. I would like to do this engine. If I decided on purchasing one, where would I do so? Would it be cheaper than doing it myself? Thanks.
... It means a lot to me. I may be idiotic for trying this but I'll never learn if I don't try....
That is the spirit of this and most other car forums. You gotta try and want to learn. The typical handicap is those that do not have time and/or money. If you have any bit of those, please go for it.
...If I decided on purchasing one, where would I do so?...
I have previously (few years ago?) web searched 2.3 engines, and found some great deals, but have no experience to suggest any company. Key differences lie within those engines & companies that offer used untested/tested/semi-rebuilt/rebuilt/performance-built engines with & without a warranty. So the price range is A to Z.
... Would it be cheaper than doing it myself?
No. Price-wise, it is cheaper doing it yourself; plus and minus the xyz factors. If you fail or struggle too much in your engine build efforts, it might be more expensive money & time wise in the long run.
But your ultimate goal is to learn engine builds right? AND the car can be side-lined for a few months or a year right?
If I was your next door neighbor, we would likely agree to only do an engine build by ourselves and not buy a rebuilt engine-in-a-box. And then learn as we go. But only if you kinda-like meticulous and careful workmanship, -and pizza, -and beer.
1 - 6 of 6 Posts
