Pics?test fitted a custom leather steering wrap
coming soon to my build thread. I have to cut the SVT oem leather off, glue the new on on and sew it up Im hoping to have it done in the next month. actually alot of updates are coming to my build thread.Pics?
Let's see some pics. I'm interested in the LED swap, myself.Waiting for dark to try my DIY LED interior bulbs to see if they're bright enough. If not I'll add more LEDs.
Anyone who says do the water pump at the same time, don't use them. It's not ran by the timing belt like some other manufactures.Let's see some pics. I'm interested in the LED swap, myself.
I called a few local shops around town for quotes on doing the timing belt. Some suggested doing the water pump at the same time, some said the water pump could be done, but isn't with the timing belt. I'm new to these motors and I assumed it would be typically done at the same time as the belt and tensioners. Can anyone lead me in the correct direction? I've got almost 83k on mine and I'm going to try t ok get this done asap.
Swapped the rear motor mount for a polyurethane cfm race mount.
I swapped out the front passenger side mount for the 3rd time. Can anyone tell me why I keep going through them? I just replaced the cfm rear mount and then the front passenger side mount, then drove it. Not even an half hour, and I didn't goose it at all. Maybe 4k shifts, if that. The new motor mount, the fluid filled front passenger mount, the little rubber top keeps popping off. Why?! Is there something I'm doing wrong?
Front dome 8 //// map 4 x2Swapped the rear motor mount for a polyurethane cfm race mount.
What are your main complaints. I just got the CFM mount and I'm just hoping to cure the slop in the old mounts.lower torque mount (to replace urethane mount I hate)
You need to make sure you use an OEM mount from ford on the passenger side mount. Not one of the cheap ones. Should run you around 80-100$. All the other ones are garbageSwapped the rear motor mount for a polyurethane cfm race mount.
