1 - 4 of 4 Posts
This should be a sticky if it isnt. This is for the grass routes racers looking for optimal gears without going aftermarket. does anyone know which cars came with the 4.06 gears and what the trans identification number is?? if I find out i will post but someone must already have asked or posted this..Yes I used the search engine with no results...
FF Affiliate
Most all the Zetec Contour MTX75 had the 4.06 gears in them, To use them they will ONLY fit in the very early Focus MTX75 trans if you have a mid 2001 or up Focus MTX75 then you have to buy the 4.06 gear set from Ford
I do have an early one, and I have found a v6 mtx out of a contour so I should be all set?? Thanks Tom I knew youd know...
1 - 4 of 4 Posts
