1 - 5 of 5 Posts
i have a 2000 SPI, and lately its been sounding almost as if it is out of gas or something??? only does it while im idle or not in gear. also, when i come to a stop and engage the clutch, the RPM needle falls really fast and then the oil and battery lights come on. then the car dies. but then sometimes it doesnt die, it will just sputter and the RPM meter goes up and down while my headlights dim.... just wondering what i can expect from my mechanic when i take it to him. im thinking it might just be my fuel injectors????? any advice would be appreciated[cheers]
FF Cleaning Squad
There is a recall on fuel pumps for the 00-04 focus, go to ford and see if has been done on your car.
If not it should be free to get done.
Moved to tech chat.
Jon
what if your fuel pump checks out as ok... can you still have them done? the PO of my car had the coil springs done because they snaped
Check for vacuum leaks as I think they are pretty common on those SPIs.... lots of people have had problems with them.
1 - 5 of 5 Posts
