Figured this was worthy of it's own thread. Daughter was driving and lost 2 and 4th gear as well as reverse. I have never worked on a transmission to this extent but I do repair manufacturing equipment, so am pretty hand with a wrench. My terminology might not be correct, so feel free to correct it.
I removed the battery and battery tray (to access the upper transmission mount.)
I removed the front driver's side tire and then removed the splash guard to access the end cover.
I removed the lower transmission mount bolt.
I put a Jack under the engine and removed the upper transmission mount. and slowly lowered the jack so I could gain access to all the bolts on the end cover. The transmission came down about and inch and a half.
I pulled the end cover off.
I then pulled the reverse drum off. It was a little difficult to get the drum out because it kept hitting fenderwall. The intermediate band had come off the servo piston and was laying loose in the case.
There is a planetary gear behind the drum that is held in with a snap ring. The snap ring was damaged and half the tabs on the direct drive clutch that
hold the snap ring in place were sheared off. This planetary gear seems ok.
I removed a large snap ring and was able to remove all of these clutch plates I think that's what they are called.
I then pulled the direct drive clutch out ( I think that's what it is called.) It has a planetary gear inside that had disintegrated and fell out in pieces with all the needle bearings that are inside it.
Here is what the planetary gear looked like in pieces. The sun gear and large gear inside this housing are severely damaged as well.
There were a few brass races and other items I removed to get to the back of the case. I believe there is damage to the case as well. In the very back where the shaft comes through, there was snap ring that is held in place by grooved tabs that I think are part of the case. Several of the tabs are missing.
Do to the case damage I believe this transmission is not salvageable. Time to start getting estimates on a rebuilt. At least I know the problem now, I wonder what could've caused such a catastrophic failure.
