1 - 20 of 40 Posts
as suggested....
as you see in the pic, my power wire is already there. there is also another hole that i will be slipping in a rubber grommet and running some more accessory wires for. the large black cable protruding from the steel is the hood release cable.
Well just be careful there cause if it gets exposed to the elements it will wear out fast. And don't let it get crimped in the door. Not to sure where you have it ran but just throwing those out there. When you get the amp and subs done throw up some pics!!!
anti svt
Discussion Starter · #14 ·
it isnt in the way of the door i have other wires going in the top plastic grommet. i wire loomed the amp wire as well so that will help.
deck
my early b-day gift from my fiancée
and my $20 sub box
in car
and just cuz my rs colection shift knob
the total cost of this set up was $340.
see that area where you rest your left foot when you drive? the area where other cars have a dead pedal, but we just have an angles flat section? UNDER THAT my friend you will find an area that is BEGGING to be drilled with a hole.
I posted once on here with some picts on how to do it. remove dr. side wheel, pull up carpet and remove the styrofoam, and DRILL taht thing out!!!
1 - 20 of 40 Posts
