1 - 9 of 9 Posts
Ok my car has a weird idle, souds like it wants to die but doesnt drop below 800 RPM's.
When the idle drops to the point where it sounds like it goin to die, the light behind the odometer gets dimer.
Is this normal or could it be a bad alternator?
yea all the accessories work i didnt even notice the light until my friend riding with me told me it was
does autozone check alts.
I agree with willybos
I agree with you and willybos, as the engine is slowing the alternator is as well therefore its not pushing enough amperage back to the battery and therefore things are getting enough power in your car. Does it do just intermittently or all the time or when its cold? is it had to turn over after it has been sitting?
Andrew
The Librarian
Moved to ”Ford Focus Technical Chat”
1) Is your car completely stock?
2) Has it ever had the factory "reflash"?
^^^This one:
http://www.focusfanatics.com/forum/showthread.php?t=1116
It was meant to cure most of your "ailments".
Though, most members around here will recommend to get an aftermarket tune to really fix it.
3) How many miles?
The battery and alternator could be getting weak at this point.
I'd start off by checking all the wiring connections and grounds to/from the battery first.
Also, check the connections and wiring at the alternator end.
1 - 9 of 9 Posts
