Hello everyone, This is my first post here usually I lurk since I never really had the funds to do anything to my car other than drool over others upgrades. Anyways I just recently found a 2006 ZX4 SES in a junk yard and decided it would be a good upgrade for my car on a low budget. Having looked extensively under my 2005 Focus I do not have the additional wiring. I have researched for hours and hours and not found any info on how to wire the Fog Lights to the 05. First of all Parts I have:
Bezels
Fog Lights
The Fog Light Switch
Connectors plus 3 feet of wire on each.
Now here is the weird part. Having looked between my Wife's 07 ZX5 SES and my car I have determined our Battery Relay boxes are different. Her's also has the PZEV. Here is the kicked the 2006 ZX4 I pulled the Fogs off of had the exact same Fuses and Relays as mine 05 did. Also I stripped the wire from the left Fog Light to the Right fog light and back to the fire wall. At the right fog light they were spiced together into a Green/Black cable at this point. Using a Haynes Manual it shows the Green/Yellow's should enter the Battery Fuse box and a Green/Black cable should go straight to the switch. In the 2006 they entered straight into the Cabin of the car. My Car has a Green/Black wire going into the 83B pin on the switch. Here are my questions.
1. Can anyone explain or pull a thread up with images on where i need to install these wires to get this as stock as possible?
2. Would anyone know why the stock wires on the junk 06 would bypass the battery junction box?
3. If so to #2 would anyone know if that Green/Black wire would run to the switch itself?
P.S. The 2006 ZX4 I found in the junk yard had fog lights stock they weren't aftermarket.
Thank you.
Jason
Bezels
Fog Lights
Thank you.
Jason
