Hoping to get some help/advice here as to how to work out what this is...please excuse the length of it---just hoping to give u guys as much info as possible...
I've been noticing what I can best describe as a clunk/snap which seems to me to be coming from near the back of the car. The sound is heard without fail while backing out when I stop transiently (it seems to occur most when the brakes are applied and there is a shift in forward/backward motion) and randomly at other times when the brakes are applied.
There is also a similar sound (I'm still unsure if its a different noise) heard if I carry enough speed and lean into a right turn---the sound appears to arise from the left rear (almost as if a spring is slipping).
There is no difference that I can notice so far in steering/handling/braking and no noise over bumps. I did think that the steering may be wandering a bit at freeway speeds (making me suspect tierods----but this may be paranoia).
Of note---I recently had the parking brake cable tightened--I'e been noticing the issue more after this--but again may be paranoia.
No accidents on the car which is stock except for EAP wheels. Rotors/Pads were changed at 31K miles---car now has 43K
I've taken the car now to 2 mechanics:
1)Ford dealer and supposedly the most reputable in the area---says brakes are great (they were the ones who tightened the cable) but the left front strut is slipping from its mounting and will need both struts replaced ($700 estimate) [nutkick]. They suggest not doing anything if not a problem---To me they seemed to be guessing--and suggesting a broad fix which they hope may solve the issue--so took it to..
2)Independant shop---supposedly the best in the PDX area--and told them this history (and what the ford dealer said)--their result--- Suspension and steering tight(no issues) Report rt front brake pad is loose--and causing the sound---suggest changing both front pads (and calipers if needed )if there are a lot of miles on the brakes else leave alone.
Now I'm completely confused by this[???
] as the 2 have opposing diagnoses---and I would bet they are both partly/mostly guessing---what do u guys suggest? leave alone till something breaks? I would have loved to follow some of the threads on here and try and diagnose it myself---but I have neither the space nor the tools[
