1 - 16 of 16 Posts
since I had my throttle body put in iv noticed a ver distinct oder comin from my focus that wasnt there before. It only shows up after I drive it hard. I couldnt place the smell at first but now I definently can tell that it smells like wax. I dont know how many of you ski or board but it smell exackt like the waxjob I get at the shop right before I hit the slopes.
WTF is this???
FF #1 Most Wanted
Your car isn't new is it ?
If it is, maybe it's that new engine smell that will burn off after a 1K miles...[scratch]
Otherwise, I have no idea what would cause a wax smell to come from your engine.
FF #1 Most Wanted
[idea]
Some things U might want to check.
1.) When U installed TB, did you use a gasket or use silicon/make a gasket ?
2.) If you open the hood, can you tell where the smell is coming from ?
Left side, right side, near air box, near exhaust, near battery, from engine itself. etc.
3.) See any smoke ?
4.) See any cables or wiring harnest touching the engine or anything hot ?
5.) Check your battery connections. Make sure they are snug. Is anything close enough to them that may short out and burn ?
6.) Is the smell inside the car in the dash ?
Hope this helps...[confused]
[scratch]
FF #1 Most Wanted
Infra3sv said:
Maybe its the old engine smell. Sorry
[hihi]
He said it started after he changed his TB and I'm wondering if he did/move something and when it gets hot, it burns...?
Discussion Starter · #8 ·
I had a shop put it in the same time they did my Cat back and CAI. woulnt the internals smell like burning rubber or plastic? this def smells like ski wax.
ski wax??? its probably just a wire getting melted
check all your plug wires and your o2 sensor wire batt cables and everything u can think of
Discussion Starter · #12 ·
its OK I took it to the shop and figured it out. its just the smell from the new muffler in the catback.
oh i dont see why that smelled lik ski wax but its cool that its all that was wrong
they probly used gaskets on the new exhaust, plus the new exhaust was probly burning off the oils on the parts
is it a stick or a automatic?
u might be burning your clutch up
1 - 16 of 16 Posts
