1 - 12 of 12 Posts
guys
Only just noticed it today but I have a constant drip of water from underneath the zx3, its coming from the engine compartment but Im not sure what it is. Im guessing it has to be from the windscreen reservoir, right ? Ive noticed that my coolant for the radiator is also below LOW , however that could be my bad maintanence. Any ideas guys ?
I would appreciate it
thanks
Are you running your air conditioner? Condensation is one possibility for water dripping, especially if it doesn't look like windshield washer fluid or coolant...
Michael J. Caboose
Check out this thread, you could have the infamous Coolant leak....
Click me
Discussion Starter · #4 ·
well ive just filled my windscreen water to max and put water just over min for my coolant, I guess I wil see which one is lower in the morning. Im guessing it wil be my windscreen water and i dont see coloured coolant leaking
Discussion Starter · #5 ·
im sure its not coolant as its just water when it hits the ground, mvhudson yeah im running my air con, it is florida you know :) silly question but is Condensation a problem ?
Michael J. Caboose
Your coolant won't be terribly colored if there is a slight leak, it will look like water...the best way to see if the leaking fluid is coolant, give it a quick taste. No really, it will taste very sweet like maple syrup (thank you Viney266 for that tip! [:D] )
Discussion Starter · #7 ·
funny JohnMichael i just searched and saw vineys tip also. Im going to wait till morning and see if the coolant or windscreen levels have lowered
guys thanks for all your fast replys so far
Discussion Starter · #8 ·
oh and as far as the condensation from the a/c, i guess i can wait till the morning to see if it still drips before i drive.
"No really, it will taste very sweet like maple syrup"
Or if you don't want to eat it, rub it between the fingers... coolant will be very slippery compared to plain water or the typical washer fluid.
Well, the car air conditioner creates condensation just like your home air conditioner. I'm not sure where the car air conditioner drains it off, but I thought it could be a possiblity for your problem. You rarely find just water under a car (unless that's all you have in your washer tank). You'd expect to find coolant or washer fluid in the water, so I'm working more by the process of elimination [:)]
Discussion Starter · #11 ·
mvhudson was on it, got up this morning, no dripping and my windscreen and coolant levels remain the same. Phew
Guys, thanks for all ur help as always
You are supposed to have dripping under the car after using the A/C for a while... if you didn't, that would be a bad sign. You are ok.
1 - 12 of 12 Posts
