1 - 2 of 2 Posts
I removed about 2 cups of water from the spare tire well of my '04 ZX3. It sounds like I still have about a gallon sloshing around, and I suspect the passenger side quarter or rocker panel. Since I'm not at home I don't have my Haynes book, can anyone give me a location of where to look for drains/plugs?
Thanks!
Vince your Moderator
I thin that they are right there. I sprayed undercoating over them to seal them(Seattle).
Most of your water is coming from the vent in the drivers side corner under the trim panel. I took a rectangle Ziplock(TM) bowl just bigger than the vent and, cut off the end so it vents. Then sealed it in place with minimally expanding foam. It leaks no more. I wish I would of took pics back then. But, I didn't have a camera.
I hope that this helps you.
1 - 2 of 2 Posts
