1 - 8 of 8 Posts
Long story short (i did not install) I have a vortech s/c'd focus (non svt) that is giving us some problems. Install was some 6 months ago and it has been running fine ever since yesterday when it died on the fwy.
towed it home and it seems like it ran out gas but I know for sure it has at least half tank.
If you let it sit for a few hours it will actually run for a few seconds then turn off. appling the accelerator does nothing.
I checked all fuel related fuses but all it good there. I know the about the fuel pump cut off switch but I reset it and nothing changed.
I read that you must send in your ECM to vortech and they send you an new custom ECM that has the correct maps. I wonder if maybe this has something to do with it not starting.
does vortech include a inline fuel pump with this kit? maybe it died?
Like I said we have not built or installed anything on this car. the install shop is over 600 miles away and they are no help. I just need some guidance on where to look. I'm familiar with hondas and turbos but not really too much focus.[???:)][???:)]
FF Affiliate
I would say check your fuel psi there is a recall on the Focus fuel pumps and this may be your problem an easy way to tell is with a scan tool and check your fuel psi
Discussion Starter · #4 ·
I was able to d/l the vortech manual the other day. It seems like the fuel pump quit so I'm going to check that first. anything else I should check?
update:
I removed the line from the fuel filter and when I turned the key fuel did squirt out but then it stopped. Shouldn't it keep on flowing if the key is on? i want to make sure its the pump before I drop the tank.
FF Affiliate
No it may not keep squirting ,,You need to test this with a scan tool for fuel PSI its the only way
You DO NOT need to change the pump it is a national recall for the focus and is free at the ford place even if you have the Vortech
if you mean the key is on the "ON" position, no it won't keep squirting. It is "priming" it for the car to start.
I miss my aftermarket one........you could hear the whine from outside the car.....it was mean.
Discussion Starter · #7 ·
another update
Ok check this out. We elected not to replace the pump since the flow of fuel out of the pump seems normal. I guess the pump does not stay on it pulses depending on the pressure.
Ne way, I leave it alone for a few hours then I think, I wonder if the factory alarm has anything to do with it not starting. At this point I will try anything. I sit in the car with the doors shut and begin to cycle thru the remote. Lock/unlock, panic etc. for about 5 minutes or so. After the last unlock I hear a click over by the passenger kick panel. Not sure if it was the ECM or the fuel cutoff switch. Excited, I insert the key and turn it. What do you know....it started!! [thumb] What puzzles me is I don't think the factory alarm has a fuel cut circuit. I thought it only locks/unlocks the doors and sounds the horn. Does the factory alarm have a fuel cut built into it? Or something that prevents fuel flow or spark maybe??
I really don't know what made it start again. [???:)] I did not do anything to know for sure if it was the alarm or not. I just came back from a 30 mile shakedown and everything seems fine.
anyone have any ideas??? strange but true.
1 - 8 of 8 Posts
