1 - 13 of 13 Posts
Jsut finished a hell of a winter and of coarse my poor baby got pounded!. ANYWAYS I just poped the hood the other day and my blue volant filter is just pure brown ehhhhhhh so does ne one know where I can buy a new one or what brand type they are?
Thanks
You can clean and reuse the volant filter a few times, after the 3rd or 4th cleaning I would get a new filter. heres a new filter here:
www.truckperformance.com focus filter p/n is 19420c
If you clean it at every oil change or every other oil change depending on your conditions, you can get 12k - 20k miles out of it.
FF #1 Most Wanted
Filter is cleaned by first brushing off any large embedded dirt.
Then spray on the cleaner and let it soak for 10 minutes.
Next, Rinse off the element with LOW pressure water. (Always flush from the clean side to the dirty side.)
Then allow filter to dry NATURALLY.
After filter has dried re-oil with the special air filter oil only.
Apply evenly to entire filter making sure to oil down into each pleat.
Then re-install making sure the element seats properly in the filter case.
I got these instuctions from HERE
f that !
44$ for a filter of nly 20k miles...
i would like a k/n...
Thats 20k miles of hard use. My volant filter is fine after 40k miles. I just said 20k mles cuz some folks were complaining about them.
Discussion Starter · #12 ·
so would you recomend getting the cleaning kit for 15 buck or just spraying it off for now then use the kit when ever i get around to buying it
1 - 13 of 13 Posts
