I posted this at the end of my build-thread but I want to make sure I get plenty of input so I'm re-posting it here by itself.
I'm currently in the tuning process following my turbo build and we've been struggling to set up a basic, healthy idle.
I'm throwing a P2195 code which is a front O2 sensor DTC. Here's the description of the code: "A HUGO sensor indicating lean at the end of a test is trying to correct for an over rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time."
I've replaced O2 sensors and Tom has modified 12 tuning files in an attempt to overcome the idle problems. Today I pulled my fuel pump fuse to de-pressurize the fuel tank so I could check my injectors and fuel rail. To my surprise, the idle stumbling completely went away when the fuel pump fuse was pulled. In fact, the idle sounded absolutely awesome for 3-4 minutes til it ran out of gas! This video repeats and demonstrates that phenomenon.
Why would this be? Any thoughts, ideas, or suggestions?
http://youtu.be/ojArEx5-_jY
