1 - 7 of 7 Posts
2006 ZX4 has a Vibration Problem replaced all the mounts and still have the same problem. You can feel it in the steering wheel after about 50 mph. you can all so feel in in the floor board as well. Where should I look for the problem now. Thanks
Mount problems show at idle car stopped. The two guys above point out things that only show at car moving.
I replaced the rear and front shocks of my dad's Ford ranger with KYB gas adjust. I did this for his birthday. He called me the next day and said the vibration he was having at interstate speeds had disappeared.
I replaced them for him due to age, but it solved problems he was having.
I once had an old MII that vibrated at 70 mph, after going crazy for a short while I discovered that the driver front frame member going up over the left front tire had cracked loose spotwelds joining it to fenderwell and other unibody there. A rivet job for about 2 1/2 foot long and problem was gone forever. The firewall vibrated quite badly around the brake pedal.
1 - 7 of 7 Posts
