1 - 2 of 2 Posts
Ok, so I decided to do some interior detail painting today (thanks boredom!) and got my oval vent surrounds off no problem. Then I figured I'd do the little triangle shaped vents in the corner of the dash, by the doors. Not so easily removed... I tried prying but they seem quite stuck in there. Anyone know if there's a certain angle I should be going for, or any tool that has a convenient shape for this job?? It's really kinda frustrating, and it was cold out, so I admittedly didn't try for very long... any ideas[?]
use a butter knife, and pry from the inside -> out. on the driver side, pry from the bottom and right. on the passenger side, pry from the bottom and left. out towards the door opening. there are 2 "clips" that hold those in. once you get it up and out a little bit, you'll be able to pull it the rest of the way.
1 - 2 of 2 Posts
