1 - 10 of 10 Posts
Here‘s my 2011. Received it last year with only 20,000mi, all original. I reckon no one wanted to see a bone stock SE sedan with two years of unwashed pollen on it, seven hornets nests in all the door/trunk/hood gaps, and absolutely zero panache so let’s jump right to it’s current iteration.
Fiesta ST Rado wheels
Cooper Zeon RS3-G1 tires
OEM driving lamp surrounds with eBay yellow fogs, KC Hilites wiring harness
WeatherTech front, rear, and trunk liner
Sparco pedals
Powerstop drilled and slotted front rotors
eBay E46 style deck lid spoiler
eBay front splash guards
Comments and questions welcome, enjoy!
305565
Discussion Starter #9
305755
Just updating as I’m finding some photos on my device.
Here were the stock old lady wheels and tires that I received the car with. The Fiesta Rado’s look much better IMO.
Note about fitment, the Rado’s bolt right up as they are 4x108 however (only) the passenger front rubbed the brake caliper. I think the offset is different than the Focus wheels by 3mm. Didn’t try swapping wheels from other positions to see if it was a wheel casting issue, just assume it was a brake caliper casting being a mm or three wider than the other. So I tried some Gorilla brand 3mm spacers - fixed the rubbing however created a vibration. Removed the budget Gorilla spacers and fitted 5mm H&R hubcentric spacers - no rubbing with these again however they too vibrated, albeit slightly less. Really couldn’t take the vibration any longer as it was just annoying once 60-65mph hit (went away above that) so removed the spacers and ground down the caliper to clearance. I know, proper offset wheels are the answer but I like the look of the Rado’s and they were affordable off CL.
The only thing I liked about the spacers is that the stance was a bit wider, specifically looked better in the back being 5mm each side/10mm overall wider.
305756
Discussion Starter #10
Did some maintenance. IDK, might sound a touch louder on the intake side, no other noticeable improvements. I run these on all my vehicles, never have a problem with them regardless of all the Internet naysayers.
305863
1 - 10 of 10 Posts
