1 - 2 of 2 Posts
03 SVTF, When I squirt carb cleaner on the little elbow behind the throttle body I get revs. What's that called and how do I replace it?
You'd have to carefully locate just where in that part the leak is. I'd bet you have to buy the entire pipe and fitting and likely not cheap and may no longer be available.
You would then have to figure out how to patch in an attachment of your own devising there.
Be careful, the stub on the intake itself may be cracked, making that part still OK but a creating a further problem.
1 - 2 of 2 Posts
