1 - 6 of 6 Posts
I'm looking at amplifying the 4 door speakers (or just the front 2) on my 05 ZX3. I have a 600 watt 2-channel amp I took out of my car that was being used for the subs. I was wondering if I could use this amp to power all 4 door speakers using the wiring diagram I found from Crutchfield. I would imagine I could use this amp to at least power the 2 front door speakers, but 4 would be better.
Thanks.
http://akamaipix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/4SVC_4-ohm_2ch.jpg
Yea you got it! But be careful with the wattage because the amp could be too much for speakers and blow them. What is the RMS per channel?
99% of door speakers are 4ohm so as long as your amp can handle a 2ohm load in stereo mode you should be fine.
The amp I'm thinking of using is a Boss Audio CH-450 2-channel amp. My other question is regarding physical connections. The amp has one set of RCA inputs and 2 speaker outputs. My Alpine head unit has RCA connections for Front and Rear speakers. This is all getting sooo confusing! I think at this point I might as well buy a 4-channel amp.
Final question: Is there a way to avoid running dedicated speaker wire to each speaker if I add an amp? I was thinking of tapping into the wires that are already run from the radio to the door. I would basically group all the wires together and run them to the amp, which I would mount underneath either the passenger or driver seat.
THANKS!
the stock speaker wire is horrible. I would recomment running larger wires. The stock wires can't handle much more power than the h/u will provide while maintaining a "clean" sound.
1 - 6 of 6 Posts
