1 - 20 of 22 Posts
I have a brand new 2003 SVT with 3k.When Im sitting in the car I can hear an abnormal amount of lifter noise.As it gets hot it gets alittle louder.If I rev the engine slightly the noise speeds up too.it sounds like its low on oil..But its not.The idiots at Ford say thats a normal charactoristic of that engine.Well If owned a few DOHC and they never were this noisey...What do you Guys think?
I don't have an svt or anything like that but my motor does it too in the middle of warming up not right when I start it but just after the oil starts to heat up then it goes away after it's at normal opperating temp. I too took my focus in to the dealer and they gave that exact same answer.... Kinda SUCKS if ya ask me, but the sound does go away....
Take a close-up analytical listen to localize the noise. I think you might find that it is an injector. They are notoriously noisy on these engines.
i have a 2003 svt and had the same concern i work at a local dealership so i checked into it and found that ford is investigating the noise for now thier calling it normal but i`ve heard talk of maybe a recall going about mid june
AKA Toyotech
pull the valve cover and check out the cams and buckets
valve chatter
Yes this is normal, believe me. You hear it alot because of the headers. (thinner metal transfers more noise. Remember this is a high performance motor. The pistons will make some noise during warm up until the metal expands. Any other questions just ask.[:)]
AKA Toyotech
OrangeSVT said:
DO NOT PULL THE VALVE COVER
lol, why the car gonna fall apart after this?..or blow up. i say to do so because the is known problems
What exactly are the known problems you are speaking of anyhow??? Tell me something i dont know about ford FSA's, TSB's or bulletins.
GOOD IDEA: TAKE ADVISE FROM A TOYOTA TECH OVER A FORD TECH....GOOD IDEA...GO AHEAD AND PULL THE VALVE COVER FOR NO REASON, TAKE THE CHANCE OF IMPOSING AN OIL LEAK AND IN GENERAL....WASTE YOUR TIME...THANK YOU
I'm just trying to help....thats all...experience over knowledge usually works and then you get experience with knowledge works better. I'm not tryin to undermine Kickinzx3 at all...ok?
AKA Toyotech
never said it was a fsa tsb or bulletin, i said it was well known. but...for 03-06-07 people have had there cams replaced...
but to the point, there has been problems with clearence and causes serious noise and even shaved the cam a little...i have seen photo's and will look when i have time if need be
pulling the valve cover may not be for no reason...IF YOUR ABLE TO SEE THE PROBLEM. damn man, sorry mr almighty ford tech. i should go sit in the corner before the focus motor is totally different then everyone out there and i know nothing. damn
ps: would u stop being such a pansy and being so cocky
I'm sorry really...i just meant unless your prepared to know exactly what your looking for , you wont really find anything...thats all, i do apologize
I do apologize, you are right, if the problem is visible it is worth the while, if you know what you are looking for. and also note that tsb 03-06-07 is not on svt motors its on standard zetec motors. Mr pansy/cockey is done speaking with you and also only about 6 of my posts were in here, have a splendid day.
Well okay then, ummmmmm just a note, but my SVTF makes the same noise and they told me it was normal.
Have a nice day all of you. lol [;)]
1 - 20 of 22 Posts
