This is probably a dumb question, but how exactly do you access the relays that are under the dash? There's a steel cover around the edges that appears to be welded to the side of the car.
there should be relay's under your hood which you can see and under the dash if you crawl underneath enough you should fine them all. that metal cover you speak of is a couple of bolts i believe to remove if you want to go deeper in.
