Brand new here:
I have really enjoyed reading the much valuable information posted here. And appreciate the fact there are so many people that love these cars to spend so much of their time discussing them...
A few weeks ago i bought a 2014 Ford Focus SE. Auction.....and even in researching decided to take the risk. The car came in. I drove around town and to work for about a week to put it through its paces. Put about 130 miles on it. No problems, really enjoying the fit and finish, handling, comfortable seats, radio not so much....too many buttons.
After taking it to emissions, which it passed, nothing but trouble with the tranny. The typical slipping, and skipping of gears, a P07A3 code. I reset the transmission a couple of times using the gas petal method and after erasing the check engine light took it for a test drive. The simptoms came back and also the code after the first stop and start. I contacted a local ford dealer here in CT and he was able to look the car up by VIN number and give me some history:
New clutch in 2017 at 54,000 miles.
New TCM in 2018 and reprogram in 2019.
I removed the clutch actuator A and sprayed some brake cleaner down into the spline of the fork in the hopes that if it was stuck physically it might loosen something up. I was able to spin the spline couterclockwise and the spring seems to be returning the fork back. Many have suggested swapping the two actuators out in the hope of returning a different code, thous diagnosing it for sure. My current situation doesnt allow for moving the car.
Is there a way to bench test an actuator to determine whether its bad or not?
I was starting to really like this car and would like to keep it...The ultimate question is if it's worth it? The car has about 113K on it now and i believe transmission not withstanding theres a lot of life still in it. This is why I'm here asking for help. I know from old posts and new ones that this is a battle with ford many have taken on and won and some have lost. Any answers, comments, and advice would be greatly appreciated. I'm thinking that perhaps the best way to go is to start fresh. New clutch, forks, seals, troughout bearing, actuators, hopefully the dealer is being honest about the TCM updates but I would like to double check.
I'm looking at the LUK 07233 clutch kit....is this a new design or original design?
What is the proper, newer color of the input shaft seal?
What is the latest firmware version of the tcm software?
Best clutch actuator brand, part number?
I have already taken the grounds to bare metal as suggested by some.
And the million dollar question...having done the work and corrected the original stuff how long, realistically will the new equipment last? The car will be used for commuting mostly, i expect it to see some traffic but not much.
I hope with some information from much more knowledgeable people than me I can makeup my mind on this.
Many thanks
Many thanks
