Car: 2013 Ford Focus SE Gas 2.0L
Symptoms:
1) battery light turns on about 1 minute after the car is turned on, stays on as the car is driven.
2) low MPG after the car is turned on, MPG improves as the car is driven.
3) engine stalls, very low power from engine for about 10-15 minutes after car is turned on, then the engine performance returns to normal.
4) car battery tested okay, no parasitic current loss, battery voltage 12.4 Volts after 2 days of non-driving.
5) car battery compartment had rain water, bottom of the battery was submerged in rain water (unsure for how long), but autozone and my own testing of the battery all reported battery is okay.
6) replaced spark plugs, didn't fix the problem
7) full battery voltage is 12.8V after trickle charge, after engine is turned on, voltage across battery terminal is 14.4 V (in normal range), voltage across battery terminal didn't drop below 14 V at 2000 RPM+AC+light+audio all turned on. So Alternator seems to work okay.
8) Has a P0456 very small leak code (replaced evap canister, didn't fix the problem), possibly the internal valve is not shut.
8) autozone checked battery, starter, alternator, all in good shape.
I am out of ideas. Any help is appreciated, can provide other information.
Thanks!
Symptoms:
Thanks!
