1 - 9 of 9 Posts
It's been fun.......
Without starting an all out UDP war on whether you should or should not
install one...... I have just one question of all the UDP (specifically the crank pulley)
choices out there is there really any difference between the crank pulley from Focus Central, Focus Sport, Esslinger, Ford Racing, etc. etc.??
Also, I did search the archives didn't find anything to answer this question.
I went with FC and I sure did feel a difference, but I think that they are all pretty good
Just wait until you take the stock one out and feel how heavy it is
Discussion Starter · #6 ·
AFX??? Haven't seen that one, where would you find it?
Everyone recommends AFX, has anyone given a reason?
i felt a good difference with my FC
AFX is $112 shipped... i had the fc 3 piece... and switched to the AFX. the AFX feels a little better, no huge difference, with the fc the water pump pulley bolts come loose so u have to keep an eye on them for a lil bit after install. the afx has the best gains dyno proven and is a great price. dont fall for the myth that the fc makes more power because it has more pulleys, the sizes of the stock crank and aftermarket water pump were swapped so it can use the same belt.
1 - 9 of 9 Posts
