1 - 20 of 22 Posts
GreyRice WOoT!
anyone think that this is possible?
i think itd be sweet to have not 1 but a twin turboed SPI fofo!!! [8] [8] [8] [8] [8] [8] [8] [8] [8] [8] [8] [8] [8] [8] [8]
oo man i would be able to run down vettes and shit, i was thinking about this all day today
man this vision could become a reality but ima need to do much research on turbos in general......
(wets pants)
man effin nuts it shall be hehe[8] [8] [8] [8]
^ one turbo is better, believe me
2 small turbos equal i BIG turbo. IMO i would just get one big one if the motor could hold it.
i'm sure a single turbo can create more boost than a spi can handle, why go with a TT setup? or is it just an originality thing?
^ dude, SPIs can handle ALOT of boost especially after a bottom end build up
Twin turbo is possible for any motor.
But just because there's 2 turbo's does'nt mean it's gonna make twice the boost and twice the power. A single system will be easyer to install and perform just as good. Maybe you should tackle a single first, then when you master that you can try for 2.
just curious, but how are you going to get around the heavy flywheel? If Ford was to put lighter ones in then we could have a better chance out there, with what i have done so far to this thing. I should be right there next to stock B16 hondas, but i seriously think the flywheel is the killer of all the potential the SPI or even the Zetec could ever have. On a lighter note GO CAST IRON BLOCKS.
The SPI-T god has spoken
viney266 said:
Anything is possible, all it takes is money.
Very true! I believe that just about anything is possible ..... however, that still didn't keep me from LOL as soon as I read the title! LOL
Anyway, the feasability and practicality of a twin turbo 4 banger is questionable at best IMO.
F2focus.com did it on the Dura I believe, but as we know, that is a completely different engine, so obviously it can happen, the real question is, will it ever?
The flywheel is'nt holding that much power back. If that was the case then my Escort with the N/A SPI swap and lightend flywheel should run 14's, but it did'nt. Not as fast as a b16 civic even with the light flywheel and 2300lb curb weight.
The heavier flywheel will help the motor create better low end torque in a FI application...... but then again faster revs are pretty sweet
FF Cleaning Squad
F1's rev pretty damn fast as is, I would hate to see what it would do with a light weight flywheel.
F1's dont really have much of a flywheel, the clutch IS the weight of the flywheel.
FF Cleaning Squad
LOL
Isn't the biggest problem with lightweight flywheels the potential to warp?
What are the chances of that happening on a daily driver weekend racer?
The biggest problem with a light weight flywheel in a daily driver is the loss of drivability. F1's dont take off from a stop doing a burn out because it looks cool, they have to do that to keep the engine from stalling.
FF Cleaning Squad
Ahh...
Ok then, so are thier other options like just a reduced weight flywheel that will help with revs but still be drivable or is it just the race flywheels?
do it good luck finding a manifold and header set up its all custom fab, I got quoted 1600 just for a single mani with a T3 set up. but I am not sure how much bost you can run.
I found out its cheaper and easier in the long run to just throw a small block in my rambler slap a 4 speed on to it throw a 9 inche rear in the back ( not sure what gears) and hold on and call me daddy
1 - 20 of 22 Posts
