1 - 8 of 8 Posts
hey i was wondering how i could wire my interior neons to come on when i open the doors
if possible could you give me a step by step or something that would be gr8
thx
northville focus
well i would imagne that if you hook it into the switch that turns on the normal lights on you should be fine. But I can't help you anymore than that.
Logan
Yeah, you could probably just splice them with the dome light. The only problem is, you wouldn't be able to operate them seperately from the dome light, and they would turn back off after you closed the door and left it for more than 30 seconds.
Actually, you could hook them up in a parallel circuit, use the signal from the dome light to operate one relay, then use a switch to operate another relay wired in parallel.
I hook my cathode from the head dome. I might do a how-to .. but like shooter posted that how to works too....
If you use cathode, be careful and make sure you know which wire is positive and negative, because if not then you can damage the converter...
1 - 8 of 8 Posts
