1 - 8 of 8 Posts
Not looking for the front turn signal diagram but the Turn Signal connector Diagram from the back of the steering wheel i want to install rear view mirror turn signals but the wiring wont reach all the way to the front, so i want to splice them to the turn signal connecter by the steering wheel ! i want to know what wires are the blink only ones for the left and right. thank you [:)]
C2H5OH
LT = BK/YL
RT =BK/BU
But if you don't understand the diagram you might not want to screw with it ... if you mess up you won't know how to fix it.
The guy had a valid question if you spliced into the rears you would have brake lights on your mirrors. :(
The diagram isn't labeled front or rear and only show 2 of the 4 expected signals.
C2H5OH
Because there are only 2 signals, blink right and blink left.
Why don't you just splice into the front lights and wire it through the fender ? I did this on a set of mirrors I used to have. You only have to use 1 wire for each side. You can ground it right at the door.
1 - 8 of 8 Posts
