The check engine light will not turn off for a minor engine coolant diagnosis. I have already tried with the scanner and battery disconnect. Is there a simple solution like the fuse etc.
I have little or no time to chat, but... P0125... common on all older cars to have a thermostat stick open, and needs to be replaced. Any 10+ year old car with the original T-stat is... Lucky?
You mean the scanner won't delete the code, or as soon as you start it up again the code comes back?
If the car reads the same situation, it'll keep throwing the same code no matter how often you delete it.
