Front driver's side turn indicator won't work. I changed the bulb but it still won't work. Any ideas on what is wrong and how to fix?
Hi estereich,
Welcome to the forum! The following tips, along with a diagram of the fuse box, are located on pages 145-149 of the
Owner's Guide: The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the CD stowage box to access the fuses. Blown fuses are identified by a broken wire within the fuse. To remove, use the fuse puller tool provided on the power distribution box cover located in the engine compartment.
If that doesn't help, I suggest visiting your local
dealer for inspection. Please let me know if I can answer any other questions. [
~Natasha
