I posted this in the local Michigan thread, but I need all the input I can get.
I need some help. I am working with Trevor (focusontheD) with his topspeed turbo'd svt zx5. He purchased the car as it sits, from a member on here with the turbonetics t3 super 60, and fully built motor.
I was driving it for the first time and I noticed that it doesn't achieve full boost until 5k rpm at wot, from any rpm. Even if I was doing 40 in second gear (~4000 rpm) it still lagged until 5-5500 rpm, then it pulls strong no matter how many gears you run it through. I don't have much experience with turbo cars, but I do no that a turbo that size should not be lagging that much.
I spoke with Brad (Mlbbaseball) and he said that it was probably a boost leak, and we tested the cold side piping and there weren't any leaks.
As a side note, he did have an incident when he was running on his high boost setting (20 psi) where his oil dipstick tube and valve cover breather blew off, blowing oil everywhere. Could both problems point to something like the wastegate? If its stuck open, it won't build enough boost, and if its stuck closed, it could spike the boost and create cylinder blowby?
Any advice is appreciated!
Matt
Posted via FF Mobile
Matt
