It depends on the turbo set up your going with... But from experience i wouldent go over the 7-8psi stock seting for a daily driver..mabe turn it up to 12-15 max when your racing on the stock engine.. anything more your going to blow the rings or worse snap a rod..Just make sure you get a good tune and try to get new injectors or have your current ones blueprinted to suit your needs. [wrenchin]does anyone knows how much psi can u put a a stock svt engine im thinkin of gettin a turbo
well who ever ran 24-26psi on a stock motor is not to smart. your car wont last more then 10 runs down the track. and yes the svt has better pistons and rods than the zetec. but it still cant take that kind of abuse. I bet that guy aready blown his motor.[wrenchin]Can't speak for him but I believe orange was running 24 or 26psi at one point and almost 400whp, then the J&S pulled timing and grenaded it or something...Either way I'd say you can very safely spike 20 and settle at 18 or something. Keep in mind the SVTs have forged pistons to begin with so they're much more receptive to boost, and that the 10.2:1 compression ratio allows you to make more power on less boost.
before you quote me look at my other posts. i know he was talken about the svt. if you want a daily driver and plan on keeping the car running with no problems for a while i wouldent go over 10psi on a stock SVT motor 12-16 at race time. anything more your going to run into alot of problems...I work at a engine/race shop and ive seen alot of people come in to get a new engine or rebuild dew to improper turbo setups. I just want to keep your guys foci alive...[wrenchin]There talking about an SVT engine. It can handle more than the zetec. Im runing 240hp @12psi right now with 150k+miles and a very heavy right foot. This is on shitty stock Zetec everything, so with an SVT 12 psi with about any turbo should be fine. Still, FocusFreak is right. Boost numbers dont really matter.
If you really want to go turbo, find someone in your area to take you a ride in there turbo car. Dosent have to be a focus, just a FWD turbo car. Get there numbers and decide if you want more, or less than ask and build accordingly.
I dont think 03Orange ever ran 24psi, but I could be wrong. And yes he did make over 400whp on the stock motor and stock fuel pump with BAP.
You will be safe with the stock Zetec to 250HP and 250TQ 14/16 boost
The SVT engine I wouldnt go over 300/300 and thats about 18/20psi boost
These are numbers that I have had customers running for years on with no issues
Well theres your problem right there "my rings went out at 75,000mi. with a focus sport pcm" Tuning is everythingIs that for a daily driver? i was runing 12psi @ 55,000mi and my rings went out at 75,000mi. with a focus sport pcm.(ecu) zetec
[sing] Piston rings have alot to do with tuning setup(ex.compression).And yes from alot of exp if your going to have a daily driver i wouldent go over 10-12psi(zetec)12-14(svt) stock motor with pcm tuned. Iam not saying a svt cant handle 20+ but if your doing that on a stock engine trust me you will run into problems.Iam not trying to get into it with people iam just trying to help people out and keep there foci alive.Oh and your right on geting the pick of the litter it depends where the car was made and assembled.Some are right on and some arent.[thumb]Tom, cut it out. All cars are different and you know damn well that 12psi on one car isn't the same as 12psi on another. It varies with the turbo, too--the efficiency and flow characteristics have a lot to do with max psi. Some people have run the zetec at 18psi with no issues but it doesn't mean you should do it, it just means they got the pick of the litter. Please, enlighten me as to how the piston rings have ANYTHING to do with tuning.
That being said, I wouldn't go above 12psi on the zetec and I agree with 18-20 on the SVT as you had quoted, but that's a mere guideline. There are plenty of other things to consider such as other supporting mods, fuel system capacity, etc.
