Hi all, I am from Croatia, Europe....I am driving an 1.8 16v Duratec Focus 2008, with 125ps.....
I readed somewhere that my 1.8, 2.0 and 2.3 have the same heads...Does that mean that i can put some parts that were made for 2.3 engine into my 1.8...
I wanted to put cosworth intake manifold and cosworth throttle body, but here is the problem....
These are 2 different cosworth manifolds, which one is one that I need to take?
Cosworth Intake Manifold Duratec HE/ ST
http://www.european-parts.net/catalog/popup_image.php?pID=562
Duratec Inlet Manifold - 2.3l (KK3240)
http://www.cosworth.com/shop_item.php?productid=72
I also have an issue about throttle bodies...First I founded this one
60mm Throttle Body Duratec HE/ ST
http://www.european-parts.net/catalog/popup_image.php?pID=881
As it looks, it replaces completly whole stock TB (including new harness & Throttle position sensor), but then I found another one from cosworth
67mm Throttle Body Duratec (YD8066)
http://www.cosworth.com/shop_item.php?productid=75
And as it looks like, it seems that the one from cosworth is mechanical TB, without electronic, throttle by cable, like on older cars...Is that true? if I take cosworth TB would I need to do transformation to non electric TB?
And one more thing...I would like to know how many sensors i have on my exhaust, because, in month or less, i mean to make completly new exhaust, fi60 like Milltek has,from headers to the end, without cat and only a single pipe to rear silencer...And then, when I collect enough money, i would like to buy milltek 4-2-1 headers, so it is also important how many milltek manifold has holes prepared for sensors....
Thanks..The other mods I want to do are: Inlet manifold, Pipercross Viper CAI, Exhaust manifold, exhaust, lighten flywheel, clutch, piper cams, wider TB, underdrive pulley kit, and than an chip which will control all that (I think it will be unichip)...
Thanks, and I hope it doesn't matter that my car is 1.8, and not at least 2.0..
Thanks... one photo
Thanks... one photo
