1 - 3 of 3 Posts
i saw someone post a link about tsbs and i went to the site and it listed all of the problems that the 05 focus has. so what does these do? i have a couple of the problems like the brake squeal and rear tire wear and hard start. what does the tsb do and how do i fix those problems?
A TSB means Technical Service Bulliten. Basically it is a problem that is common enough that Ford tells the techs about it through these TSB's. So if you have a problem with your car, and it fits the TSB description, that is most likely the problem. Unfortunantly they are not recalls or necessarily free warranty work. Just Ford alerting techs to common problems with the car.
1 - 3 of 3 Posts
