1 - 6 of 6 Posts
the thing is my clutch went out so i am trying to drop the transmission but i am stuck with these two cables behind the transmission which i believe its for shifting the gears,which u can twist but they are also spring loaded, i tried twisting them and nothing really happened so idk how to undo them, so if any of yall knw what im talking about plz help me out,
Token Engin-nerd
it is a ball joint, just pop them off with a screwdriver
but if you are talking about where they connect to the black bracket, then those two plastic parts unscrew away from each other. turn them counterclockwise.
Just a question, I'm planning on replacing my clutch when it goes out (hopefully not soon, but it has 160k on it). How easy is it to drop the tranny to put a new clutch in?
I have access to a lift whenever I need it, but what are some things I need to do? Does it just unbolt from the engine, or are there other things attaching it to the engine?
1 - 6 of 6 Posts
