1 - 8 of 8 Posts
I want to replace the bulb in the trunk with an LED bulb. I removed the trunk lamp assembly but I can't figure out how to remove the bulb. Does anyone know how to remove the bulb? Replacement LED bulb?
Thanks!
If you have the sedan, there is a slot on the drivers side of the lens. I just used a flat screwdriver to pop it off. The socket is attached to the lens and I just wiggled the bulb out
Discussion Starter · #5 ·
Got it...thanks! So what size wedge type LED bulb did you use to replace? I don't want one that is overly bright.
Discussion Starter · #7 ·
1 - 8 of 8 Posts
