Hi mustv8,Sorry i thought this was a real common problem, Its the latch it will not stayed closed.
if you use the button to unlock. The motor works to unlock. right now i have the plug for the motor unplugged, it works fine by the key on the trunk.
I have had the latch apart and what i can tell is that if the motor stops in one spot it will keep the latch unlatched. so if i get the motor in the right spot i can use the key just fine. I have made sure its lubed good and motor works fine. By the way it makes a ratching noise when using the button is this how thy all do.I'm still confused. When you close the trunk, it doesn't latch again unless you do it manually with the key?
I don't think I can help you much with this. I have only had trouble with the button inside the car and haven't heard of anyone else having this issue.I have had the latch apart and what i can tell is that if the motor stops in one spot it will keep the latch unlatched. so if i get the motor in the right spot i can use the key just fine. I have made sure its lubed good and motor works fine. By the way it makes a ratching noise when using the button is this how thy all do.
